transmission /oil cooler ?? >
Old 02-05-2009 | 04:13 PM
Default transmission /oil cooler ??
Hello All,
I'm looking at a transmission cooler which is longer than my oil cooler, what is the differnce between the two for cooling. Can you use a tranny cooler for engine oil ? I need a larger cooler than my stock 13 inch oil cooler does anyone know where I can find on with NPT fittings.
alecsammy is offline
Old 02-05-2009 | 04:19 PM
Originally Posted by alecsammy
Hello All,
I use a stock 12 " oilcooler for my tranny and the 2 on the bellhousing for the engine . Works fine !!! Why would u need a bigger one ? What kind of tranny and what power ?
DareDevil is offline
Old 02-05-2009 | 06:17 PM
I have no transmission , I need a larger engine oil cooler. I found a 17 inch tranny cooler but not sure if I can use it for engine oil cooling. I have not seen the tranny cooler,not sure if its the same as a mercruiser power steering cooler .
Old 02-05-2009 | 06:56 PM
marinetrans's Avatar
Trans. cooler are usually 2" dia. with 3/8 npt fittings.You need at least 3" dia with 1/2 npt fittings.
marinetrans is offline
J. Hordubay
13
10-02-2008 01:55 PM
31scarab31
2
02-29-2008 04:14 PM
slik22
Wanted
6
01-08-2008 04:13 PM
patrick22309
5
06-20-2003 05:53 PM
77Superboat
4
01-14-2002 11:18 PM
