What is chinewalk? >
What is chinewalk?
What is chinewalk?
Old 02-06-2009 | 02:17 PM
Default What is chinewalk?
What is chinewalk?
How is this to be solved or reduced?
chris
chris-jack is offline
Old 02-06-2009 | 02:48 PM
You will know it when you ride in a boat that does it, it rocks back and forth
A way to solve it, I don't know slow down. Maybe trim tabs. Best solution buy another boat.
Years ago(many years) I built up my first V8 in a boat that had no business going faster and it was scary to say the least.
1BIGJIM is offline
Old 02-06-2009 | 03:32 PM
AIR TIME's Avatar
Keep It Up Right Its More Fun
what I do once it starts you have to move the steering wheel both ways until you hit a rythm that your arm is moving a lot and the boat is even, to help cure that you need a FULL HYD STEERING TWIN PISTONS. I had the add on steering it did zip over 80, my arm would lock up at the end of a trip if I had the boat speeding at wfo. so I hope this year my full steering will cure it or slow it down since I plan on running a 100 plus from mid 80s. if your out cruising upper 60s and it happens from a wake just chop the throttle and it should stop. on stock steering what happens is the cable has play or outside the gimbal bolt is worn. hope this helps. ARTIE
Last edited by AIR TIME; 02-06-2009 at 09:25 PM. Reason: steering sounds better than sreering
AIR TIME is offline
Old 02-06-2009 | 04:59 PM
ChristianGott's Avatar
I thought it was a leisurely stroll along the Great Wall...
ChristianGott is offline
Old 02-06-2009 | 05:07 PM
Originally Posted by chris-jack
What is chinewalk?
chris
Bet I've posted about this 25 times in the past few years LOL
After I dropped in the ZZ502/502 my 23 Nova would begin to chine walk at about early to mid 60's. By the time I got to late 60's or 70ish on the GPS, it would be down right scarey!! I contacted Throttle Up and discussed it with Matt & Julie. Long story short, they labbed/tweeked my Mirage 25P prop, and NO more chine walk. None... zip.... nada.
Last summer after a little engine work, I had the Humble Little Nova a little over 80 on GPS spinning a bone stock Mirage 27P. And with that prop, there is no walk... go figure
Every hull and prop is different. Try talking to Throttle Up, they may be able to help you out. Best of luck!!
Kidnova is offline
Old 02-06-2009 | 05:22 PM
The best way to eliminate it ,,is to drive thru it,,,,,,,full throttle and tabs level ,maybe a tick down and do not steer against it try to steer withit untill it setles down,,,now u are on the tip of the V and the air is flowing along each side of the chine ,(outer edges of the hull) !!!!!!!
Takes Ball$ to do so but once done no problemo,if the boat has enuff power to do it,,,,not easy and u can flip the boat if u don't watch it.
DareDevil is offline
Old 02-06-2009 | 05:28 PM
Default Good question---
What is chinewalk?
chris
a. What is chinewalk?
Its the rocking of the boat from side to side-like a cradle rocks typically getting worse as speeds increase.
b. How is this to be solved or reduced
Money
All kidding aside, it could be as expensive as a new boat, to a prop, to tabs, or bottom end job,hydraulic steering etc.
The guys answering so far have been giving good advice.
Uncle Dave
Uncle Dave is offline
Wild Card 09
Drives and Lower Units
9
01-14-2011 08:51 PM
bouncedcheque
22
06-11-2005 11:21 AM
crmax
8
03-19-2002 02:31 PM
