engine compartment >
engine compartment
engine compartment
Old 02-10-2009 | 04:19 AM
I will dig some out from my other computer later today for you.
Young Performance is offline
Old 02-11-2009 | 08:39 AM
Here ya go Conquest. These were done with the Interlux Bilge Kote in white(obviously)
The first pic is a before in white gelcoat.
Attached Thumbnails engine compartment-38-stryker6-large-.jpg   engine compartment-38-stryker3.jpg   engine compartment-38-stryker2.jpg
Old 02-11-2009 | 08:42 AM
Here is another before and after. You will not be disappointed if you use the Bilge Kote. Hope this helps, Eddie.
Attached Thumbnails engine compartment-envision-006-large-.jpg   engine compartment-envision-010-large-.jpg   engine compartment-envision-011-large-.jpg
Old 02-12-2009 | 12:06 AM
thanks for the picture. after reading the application process it seems very time comsuming. any tips?
conquest30' is offline
Old 02-12-2009 | 03:35 AM
Not at all. Just rough up the surface and either roll or brush it on. It's that simple. I like to hit the surface with 80 grit paper on a DA or orbital sander. Then wipe it down with acetone or similar and paint it. You will probably need 2 coats, depending on what you are going over. Put on one coat, wait 24 hrs, and recoat it. That is all there is to it. It will flow out great and not leave any brush or roller marks. It will look like it was sprayed on. It really is some good stuff. Hope this helps, Eddie.
Old 02-18-2009 | 11:16 PM
how should i prep it, its stock so i dont know what surface it is, but its clear. probably fiberglass underneath? i dont know if its clear coat or epoxy?
Old 02-18-2009 | 11:26 PM
First u need to find out if its a epoxy built boat or a conv. resin built boat.
I don't think its clearcoat !!!! either one of the above.
but not everything sticks to epoxy ,,only epoxy related products will stick to it,,with polyester or vinalester its a difrent story !!!!!
DareDevil is offline
Old 02-18-2009 | 11:32 PM
well im using bilgekote, and i believe it is resin cause it has that on other parts of the boat, but the floor looks perfectly laid, its a older boat if that helps 94 conquest. the was carpet down before
Old 02-18-2009 | 11:49 PM
Yes ,, thats what u need . I think 99% its not epoxy !!!
Just sand it so all the erea is skuffed up and then clean with a rag and aceton ,,then mix the bilgecoat with wax (if its not premixed with it ) then just roll it on ina nice thick coat and let it dry !!!!
Old 02-18-2009 | 11:57 PM
cool thanks for the help, i have fiber solvent wash 202, and brushing liquid 333. what do i use to wipe down. thx for the help daredevol im planning on doing this is the morning
