330hp 454 rocker stud question >
Old 02-11-2009 | 10:03 AM
Default 330hp 454 rocker stud question
Hey guys I was going to do a camshaft swap with new lifter, springs and roller rockers on my stock 330hp 454. Bob from RM builders is the guy helping me with the proper camshaft,etc. Anyway the boat is shrink wrap as of now and there is now way for me to acces the engine. What I need to know is the stock peanut port oval heads on my motor use pressed in rocker studs or are they screw in rocker studs? I never had the valve covers off so iam not 100% sure but I thought these motors have pressed in rocker arm studs.
thanks for any help
Erik
crapr6 is offline
Old 02-11-2009 | 10:24 AM
thanks for any help
Erik
No, they screw in. You can change to a roller rocker if you want to , but it is a huge waste of cash fu(king with those heads. You can buy a brand new set of oval Merlins from JEGS for $1600 shipped to your door, and they will work fine for what you are trying to do.
Tell Bob Jeff Says hello, and to get his but to the boat show.
jeff1000man is offline
Old 02-11-2009 | 12:10 PM
99.9% sure They use the non adjustable shoulder bolts. You can look up your engine on www.mercruiserparts.com to verify.
The ARP screw in stud kit is about $35
http://store.summitracing.com/partde...5&autoview=sku
Griff is offline
Old 02-11-2009 | 12:12 PM
I didn't mean rocker arms, I was just meaning that the treaded holes are there to put the rocker studs into the head.
What he said.
Old 02-11-2009 | 02:11 PM
Ok thanks guys for clearing this up for me.
Erik
crapr6 is offline
Old 02-12-2009 | 07:04 AM
as said before you are wasting time and $$ with those heads....junk for any performance....even a set of good large ovals (781's) would do wonders...
ezstriper is offline
Old 02-12-2009 | 10:30 AM
Thanks yeah I just wanted to make the boat run alittle better for this year and build a new motor over the next winter, but I may just leave it for now. thanks
Erik
crapr6 is offline
CN24
6
05-12-2008 10:06 PM
ratman
08-21-2005 07:32 AM
ratman
1
08-21-2005 07:29 AM
BAD-HABIT
12
03-28-2003 03:35 PM
88 MACH 1
08-11-2002 11:06 PM
