leak down results 2nd motor >
Old 02-17-2009 | 05:28 PM
KAAMA's Avatar
Originally Posted by Griff
I would not reuse the lifters with that many hours on them. A broken lifter can trash the entire engine. If you go to a larger cam, I don't think you'll be able to use the GM roller lifters anyway.
Yeah to what Griff said! Start/Rebuild with new lifters!
KAAMA is offline
Old 02-17-2009 | 05:53 PM
OK thanks again griff, i will replace cams, lifters, chains & gears, heads i will cut, new valves, springs ,guides ,locks retainers, seals and all new gaskets. what about my gold crane rockers ??? and push rods.
rssteiny is offline
Old 02-18-2009 | 12:48 AM
I would probably reuse the rockers after inspecting them very well. They shouldn't have any lubrication issues with the way the engines were maintained. Also, the risk is not nearly as high if a rocker goes bad compared to a lifter.
Griff is offline
rssteiny
9
02-16-2009 05:26 PM
scandelous
OPA/The Jersey Boyz
2
09-24-2007 05:20 PM
cig1988
12
05-16-2004 07:50 PM
XCAV8
6
07-12-2003 06:23 AM
