now my valve covers wont fit!!!!!
The new Crane Golds are different and they should actually fit without grinding. My 525SC valve covers were exactly the same casting as my 454mag ones. They had the drip tabs ground off from the factory. They fit with no problems with Crane Golds and .610 lift.
i wonder if anyone has a port side gil. ine has a crack. im getting it welded but i must admit im a little queazy about it. also mr griff... thanks for the speedy shipping. it was everything i needed. thanks again
Where is the crack???? At the top between the dividers???? Thats where mine cracked and its pretty common.
It may be ok welded, but I'd keep an eye on the amount of steam coming out your exhaust. My hairline cracks cost me a couple exhaust valves.
i plugged the supply side fitting. then if you notice the rear drain is the same npt as an air chuck fitting. i installed a regulator in line... i plugged both top holes. i filled a barrel with water and applied 20psi to the manifold and submerged it in water to watch for bubbles. one is great but the other needs rescued. mabye ill gind someone with a partial set.
