How many HP is a 454 mag?
Do the exhaust first. You need it for any cam upgrade. I have EMI with long risers with no silent choice. Do not get short risers if you plan on doing a cam upgrade. Exhaust will give you about 1 or 2 MPH on a stock engine. Good Luck!!
If you simply bolt a blower on your 365, then you would not neccessarily need an upgraded exhaust system, however anytime you can add a better breathing exhaust system over the Merc stock exhaust is a HUGE improvement!
By the way, you do not need to change the heads on those 365's....just have them checked for cracks between the seats, then have them bowl/pocket ported while paying attention to the short side radius. "JimV" (Michigan) would be good for that 616-889-0928. Add a Holley 750cfm carb, single plane intake, roller rocker arms, then for a cam selection you can install a good hydraulic roller and HANG ON! For the custom cam I recommend "RMBuilder"/Bob Madara of Marine Kinetics in N.Y. 585-654-8583---he's the cam guru and will grind you a cam profile for your combination and specific application. Have fun.
