Reversing engine rotation >
Old 02-26-2009 | 11:08 AM
Default Reversing engine rotation
What is required to reverse the rotation? Say you have a standard BB, what is needed to reverse it? Does it have to be totally rebuilt, or just swap say cam, dist gear, etc?
MILD THUNDER is offline
Old 02-26-2009 | 12:23 PM
Starter.
Cam has to be gear driven so it
still rotates l/h to drive oil pump
properly.
Pistons have to be rotated
180* to change pin offset ( the notch that usually
faces the front of the engine needs to face the back)
Crank seals can be rotation specific.
I'm thinking the circulating water pump might too.
JaayTeee is offline
Old 02-26-2009 | 12:46 PM
I've heard yes and no on the pistons.
You can buy reverse rotation cam, gear drive, etc from merc. But I think the only ones still available are the 340hp inboard cams. Also not sure if these parts can be used on Gen V or VI engines.
Definitely a new rear seal.
Some recirculating water pumps are bidirectional, you'll need to check your current one.
Simple stuff, change the firing order, and swap the inlet/outlet of your fresh water pump.
Originally Posted by JaayTeee
Starter.
properly.
rdoactive is offline
Old 02-26-2009 | 01:04 PM
Ateco's Avatar
I'm In The Process Of Building A Reverse Rotation Engine For My Boat To Run Arneson Asd-8 Drives. Need To Change Gam, Starter, Sea Pump.
Ateco is offline
oldandtired
2
02-26-2007 01:50 PM
tracybrown
4
08-16-2005 10:17 AM
IndianaHeat
4
02-09-2005 04:21 PM
CN24
11
02-02-2005 10:19 AM
blue thunder
14
04-02-2002 08:17 PM
