N/A 540cid or supercharger >
Old 03-06-2009 | 01:33 PM
Default N/A 540cid or supercharger
I would like to build a motor over the winter next year for my boat. I was thinking a 502 based n/a stroker motor like a 540cid. Well after thinking about it iam up in the air with a N/A stroker motor or a blower motor. I would like to make 500-600 relible hp. I allready have a good running 454 330hp motor in the boat.
So here it goes. If I do a stroker 502 its going to be a gen6 block which none of my 454 stuff will swap over to. The stroker 502 will need a good camshaft and roller lifters, Alum heads,intake,etc to make the power I want N/A.
If I do the blower motor it will be using my 454 but of course will be rebuilt with a "better" set of iron heads, blower cam,etc I can reuse my front cover, oilpan,etc and will make the hp goal easily.
So do I do the stroker motor or blower motor? Also if I do a blower motor which blower set-up should I do Roots, centif, or wipple?
Erik
What would be
crapr6 is offline
Old 03-06-2009 | 01:46 PM
Your 330 has all cast internals and most likely has 2 bolt mains. If its a 2 bolt block, forget it. If its a 4 bolt block, you could stroke it to a 496ci. Find the block casting number and look it up on www.mortec.com
All of the parts you would need for an NA 540 would also be needed if you wanted to SC the 454.
Griff is offline
Old 03-06-2009 | 02:29 PM
Every good point and deffinaly something to think about.
crapr6 is offline
Old 03-06-2009 | 04:30 PM
Erik
What would be
You can get 600 hp reliable from 502 CI with good heads, like AFRs. Plus cam, intake, carb, etc. Stroke the 502 to 540 and get more than 600 easily and still stay reliable.
Unless I wanted over 700-750 hp I wouldn't bother with SC.... no need for it. JMO
Kidnova is offline
Old 03-06-2009 | 07:32 PM
Ron Sprol Has built 3 Motors For me and one Was Super charged made 825 HP
The Two other Motors Were Merc Fuel injected Made 675 each No Problems at all
He Had a motor in Power boat last mouth in a Red Line cat
160 hours on Twins
165 on the super charged
Solid motors
Call Him 504-616-6005 Or Me Gerald 423-593-5841
gnorthga is offline
Old 03-07-2009 | 12:40 PM
KAAMA's Avatar
A naturally aspirated 540cid engine is more than adequate for the power you are wanting....500-600hp. Actually, a 502 will still do the job nicely and still not require any assistance from a blower.
KAAMA is offline
Old 03-07-2009 | 12:53 PM
I Agree 540 with AFR's and cams 650 HP no problem, stay away from the blowers if you dont want to be a weekend wrencher.
laszlo01 is offline
Old 03-07-2009 | 07:18 PM
Ok thanks guys. Looks like i'll stick with N/A.
crapr6 is offline
Old 03-08-2009 | 01:04 AM
Blower engines can be plenty reliable and don't require hardly any added maintanance if built correctly.
If your 454 is a 4 bolt block, you can easily stroke it to a 496 and make 500+ HP easily.
Griff is offline
Old 03-08-2009 | 02:06 PM
I agree 100% on the reliability if built right.
But, a studded two bolt block is plenty strong. I've run lots in the 500hp to 600hp range with zero failures. I've got a two bolt 496 in a customers commercial jet boat with 1600 hours on the bottom end..
HaxbySpeed is offline
