Imco Powerflow exhaust manifolds, good or bad?
If any one has a set and needs a spare manifold or two spare SS risers, let me know. I recently pulled a set off my 540. The "bad" manifold has one of the screw holes stripped. It could probably be tapped or helicoiled, but is currently pretty useless to me.
Those are IMCO Powerflow PLUS manifolds. Water is introduced into the exhaust stream alot further down than in the plain IMCO Powerflow manifolds that I think Cold Sweat is talking about.
I've still got them. Just to make sure that you know which ones they are... they are not the PLUS ones. They're like these:
http://imcomarine.com/ca_store/image...it-02-8312.jpg
but they have the round holes instead of the triangle looking water passage...
Essentially.......none. You will not see any appreciable gains with just the exhaust. Most guys change them because they either want the look of aftermarket exhaust, the cast iron stockers are leaking, or they intend on future upgrades so they will need to be changed at some point anyway.
Eddie
Eddie
Any exhaust out there where I would find some HP gains that would be noticable? I'd be happy just bumping my motors up to putting out around 500hp at the prop, but from what I've read there's not many if any options without new cams, heads & intakes, which currently will not fit n my budget.... Eddie I ever hit the lottery or accidently fall into some nice cash you'll be getting a call
Not really without tweaking the EFI.
My experience on a carb setup is that you will gain a modest amount of power. I used the imco powerflows (not the plus's I showed in the other post)
Your exhaust is the foundation by which all other engine mods stand on.
tpmarine.com
New Products and Member Discounts
5
05-19-2008 03:24 PM
