Overheating
Old 03-22-2009 | 07:26 AM
Default Overheating
I posted this on the Fountain forum also:
I took my boat out yesterday (Fountain 47 with triple 502's) for a "shake down cruise" after 4 months of heated winter storage. The motors started fine, sounded fine, and the guages all read fine but all three overheated after about 15 minutes. I shut them off and let them cool but when I started them again there was no water pressure and they overheated again. I can't believe all three pumps went out simultaneously but I'm not sure what else would have caused it. Gross inspection looked ok although the manifolds were a little hot to touch (not terrible). Intakes also looked clean. Any suggestions?
pookie is offline
Old 03-22-2009 | 07:34 AM
impellers might have got hard and crusty, then just fell apart, seems hard to believe 3 would do that, but you never know
Boomer35 is offline
Old 03-22-2009 | 08:24 AM
jeff32's Avatar
like I said in fountain forum...
jeff32 is offline
Old 03-22-2009 | 08:41 AM
blue thunder's Avatar
Did you have water pressure initially?
blue thunder is offline
Old 03-22-2009 | 08:53 AM
MER Performance's Avatar
Did you run the engines on the hose first, if so you had at least enough water in the system. Is there a common hose connection for all 3 engines? Check to see if manybe there is a leak allowing the pumps not to pull water.
MER Performance is offline
Old 03-22-2009 | 10:28 AM
DORaymond's Avatar
Are there inlet sea cocks that may be closed?
DORaymond is offline
Old 03-22-2009 | 12:36 PM
there are but they were open.
pookie is offline
Old 03-23-2009 | 06:23 PM
Payton's Avatar
Charter Member #927
was there water coming out the exhaust?
Hook up a water hose to the line coming out of the water pump and force water backward. Maybe a family of mice thought it was a condo.
Payton is offline
bajahaha
24
11-10-2007 11:22 PM
GoodTymn
Baja
24
09-10-2007 10:13 PM
Gnational
7
08-07-2007 04:14 PM
newkerofmi
3
06-23-2007 08:12 PM
