TRS - engine R & R help.... >
Old 03-27-2009 | 10:25 AM
Biggus's Avatar
Originally Posted by Rookie
Not to Hi-jack this thread, but the bearing that you are talking about is it serviceable without pulling the tranny? I thought I heard people replacing the gimble bearing on a TRS boat, this must be the bearing they are replacing???
I thought I read where you have to cut something out to access this.
If the TRS application is fitted with a Brog Warner (Velvet Drive) tranny, the tailstock bearing is replaceable through the bellows. (held in w/snap ring)
If fitted with the MercTrans, the motor/trans must be pulled to replace the bearing. Although I have replaced it by removing the gimbal housing but I'll never do that again, -huge can o worms...
Biggus is offline
Old 03-27-2009 | 12:06 PM
Rookie's Avatar
That is great news, I have the Borg Warner. I heard the bearing starting to howl last year right before I put it up.
Rookie is offline
Old 03-28-2009 | 11:58 AM
bobbowobbo's Avatar
replace it!!! I spent two days trying to seperate(pull) the motor with a seized bearing, I finally had to make a tool to release the bearing from the tail housing to get it apart. bad memory
good luck
bobbowobbo is offline
Old 03-29-2009 | 01:05 PM
spazboz's Avatar
Default TRS alignment tool
You'd be busy trying to install on a Bravo boat.
TRS has no gimbal bearing, just a trans tailstock bearing that's fixed.
The TRS has a rather long input shaft so it's not too bad getting it to line up. Here's a pic of a BW fitted with a TRS tailstock.
The TRS alignment tool inserts into the tailstock of the Transmission and align's the transmission with the bell-housing of the gimble. It is similar to the Alpha/Bravo tool except it has a large round disc on the end that couples into the inner hole of the bell housing. Alignment has been achieved when the disc lies completely flat with the surface of the bell housing that bolts to the outdrive. I will take a picture of it Monday when i get to the shop.
Nick
spazboz is offline
Old 03-30-2009 | 08:34 PM
Default pic
Nick[/QUOTE]
thanks for the pic when you send it.
John
getrdunn is offline
Old 03-31-2009 | 04:47 AM
Scott B's Avatar
Scott B is offline
Old 03-31-2009 | 01:37 PM
spazboz's Avatar
Hey, thanks for the shot Scott. I keep forgetting to take the picture. That would be the creature. PS- I think your gaskets broke!
spazboz is offline
Wally
124
11-16-2014 03:53 PM
spazboz
09-04-2008 11:19 PM
J-Bonz
Apache
4
12-20-2006 08:46 AM
JLANE
2
05-16-2005 03:16 PM
boatman747
39
02-26-2005 12:29 AM
