TRS - engine R & R help....
I pulled my engines out this past winter without pulling my drives. This went quick and easy. The question I have though is what about putting the engines back in. The drive shafts kind of do the weeble wable thing and I am not sure how you keep the alignment when lowering and moving the engines/trans back to place.
The last time I did this (years ago) I had pulled the drives before pulling the engines. I could still pull them and reinstall them however I'm looking for an easier way out . I can't see any way to hold the shafts in place during or when getting close to engine placement. Thanks for any help. John |
my guess is you have to take them off or, maybe turn the prop so the spline slips in your tranny... but I never did what you've done.
On my TG, I never remove the drives when swapping motors.
When you're lowering the motor in, just feed the input shaft into the trans and have someone tun the prop slowly. Usually less than a turn of the prop and the shaft engages into the spline. I've never had even the slightest issue. Kurt |
that might work. sounds like a job for the b-i-otch. maybe she can hadle that job better than putting fuel in the caddy today. did i forget to mention diesel fuel into a gasoline engine. Ya, that was a nice phone call late this afternoon right after i backed over my sons ATV with my Ram 3/4 ton.
i felt like throwing myself in the outdoor wood boiler and calling it a day. John |
thank you both for the help. as noted i'm sure you see why i'm not thinking clearly at the moment.
I always pull the drives and check alignment. I know people who and have never had any issue's. For me personally I just like to know that its all running true.
Funny
Originally Posted by getrdunn
(Post 2830020)
1 Attachment(s)
Originally Posted by spazboz
(Post 2830030)
TRS has no gimbal bearing, just a trans tailstock bearing that's fixed. The TRS has a rather long input shaft so it's not too bad getting it to line up. Here's a pic of a BW fitted with a TRS tailstock. |
What biggus says is how i do it. While lowering, just feed the input shaft into the tailstock, and once its in, have someone turn the propshaft while you put a little pressure pushing the motor/trans assembly towards the transom, it should slide right in.
Originally Posted by Biggus
(Post 2830204)
I thought I read where you have to cut something out to access this. |
| All times are GMT -5. The time now is 03:39 AM. |
