E-85
Old 03-27-2009 | 07:05 PM
Default E-85
Any one using e-85?If so what are the pros and cons of it
dennis r is offline
Old 03-27-2009 | 07:20 PM
Do not use E85 in a boat, E10 is bad enough but that is all I can get. Alcohol absorbs moisture and separates from the fuel over time. On top of that is has a lower BTU output so you boat is slower.
jeffswav is offline
Old 03-28-2009 | 02:01 AM
You can't use E85 in a boat engine...or for that matter any engine that is not specifically tuned for it.
Griff is offline
Old 03-28-2009 | 10:36 PM
I have another opinion. E-85 is great for performance. It has a higher octane rating and you can run more timing. I would agree that it will atract moisture and may not be great for boats. I have ran E-85 in performance street cars for years and love it.
SUN-CHASER is offline
Old 03-29-2009 | 01:21 AM
You still can't run it unless you tune the engine for it. It takes a lot more E85 than gasoline to make the power. You have to run a lot bigger jets or injectors to flow enough fuel.
It most likely can make more power and you can run more timing, but you will use 50% more fuel. You're also screwed if you run out on the water.
Griff is offline
Old 03-30-2009 | 06:27 PM
My boat runs faster on Pure Gasoline that E10. I have never used E85 in anthing. I do know that they use the ethanol to boost the octane rating. But the BTU output is lower with ethanol. Maybe a petroleum expert will chime in.
jeffswav is offline
Old 03-30-2009 | 07:02 PM
If you look at all of the current cars out there that are E85 compatiable you'll find they are all using stainless steel fuel lines. Why because it eats through everything else. I find it hard to believe someone ids getting more out of E85 than the rest of the pump fuel. Leave the crap at the pump for those green guys that think there saving the world. Costs more provides no benefits other than cheaper at one time but now it costs more and you can't go as far. Give it a few more years and I'll bet you won't even find it. Oh ask the outboard guys about it and I'm sur you'll get an ear full
Hot Stepper is offline
Old 03-30-2009 | 07:10 PM
I was thinking of a cheaper way then racing gas if your boat was set up for it. but I was thinking it would eat your alm. fuel tank
dennis r is offline
Full Force
Chris Craft
14
10-29-2006 09:26 PM
blownincome
03-14-2006 12:48 PM
Anarchy Powerboats
09-15-2005 02:22 PM
Monty
Cigarette
24
07-25-2005 12:39 PM
pullmytrigger
04-16-2002 09:32 PM
