Innovate air/fuel ratio meter
Thanks!
The black transom shows up at all rpm's and at idle the exhaust definately smells a little rich. I was also thinking 13.5 at idle/low rpm's and 13 mid range and 12.5ish for high rpm. The spark plugs always look clean, but that could be from the high energy ignition on the 496's.
I will talk to Dustin at Whipple - I'm running Whipple's Stage 2 ECU, so hopefully he can retune it leaner.
Had a great day on the lake yesterday. I still can't figure out how to recall the air/fuel ratio data logs, it keeps coming up "invalid data file". I will have to phone Innovate on Monday-I'm sure it's something simple that I'm missing.
I got the wife to write down the a/f ratio's at 500 rpm increments, made four runs. Seems rich at idle/low rpm, not sure about the rest, what do you guys think?
5000 rpm is the most I could get with a labbed 28p bravo.
I included a quick video of the wife driving - she loves that Baja!http://www.youtube.com/watch?v=KSyj8DWBYJM
Dustin at Whipple has been a great help. After sending him my numbers, he suggested that I lower my fuel pressure by 5lbs (50 down to 45). I'm a little cautious with this engine so I went down 3lbs - it brought my AF up from 12 to 12.3 avg. 12.5 is my target with the aluminum heads so I'm going to go another 2lbs lower and see what happens.
I'm still very rich at idle and low rpms (12.0), so I will send the PCM to Dustin at the end of summer to clean that up. I have picked up about 100 rpms already, so there is definately a few HP being left behind by being too rich. So far best mph is 73.5. I sent my labbed 28p bravo to Bblades to get tweaked a bit more - I would really like to see 75 on gps this year!
I picked up Hardin Marine's new 496 flame arrestor - l don't know if it flows better than the K&N, but it sure looks great!
Will update after running with lower fuel psi.
I dropped the fuel pressure to 46lbs and it raised my air/fuel ratio a little more. I am seeing wot a/f of around 12.5 and mid-range (3000-4000) a/f of about 13.5. This seems about right. The idle/low rpm a/f is still too fat (12.5) so I will send the PCM out in the fall to get that leaned up a bit. The transom soot is still just as bad though. I spoke to Ray @ Raylar and he is insists I should only be running 87-89 octane (I'm too chicken to go below 91 because I heard the Whipple Stage 2 calibrations shuts off the knock sensor/timing retard program in the PCM). He said they found 12.8 to be the best a/f ratio, so I might drop another pound or two and see what happens.
BBlades got my prop back to me in time for the run - as promised (Thank you Brett!) I picked up another 150 rpms and almost made 75 (74.5 with 3/4 tank & 2 people). Boat ran great!!
I thought Ray told me WOT A/F ratio was supposed to be around 13.5?
Isnt 12.5 still kind of rich for WOT?
FYI - test your stock flame arrestor - mine performed 1 MPH better than K&N and the Hardin.
I was told 12.8 at wot and around 13.5 mid-range cruise, Dustin at Whipple told me 12.5, I think he's being cautious.
My main concern now is cleaning up the idle/low rpm's. That is where most of my transom soot comes from. I notice a huge difference when I run the exhaust through the leg at low rpm's compared with running it straight out.
My stock flame arrestor is long gone. The Hardin Marine arrestor seems pretty good, I took out probably three-quarters of the stainless mesh (left two layers in) - I also took a grinder to the inside of the little velocity stack on the arrestor and smoothed out all the edges.
