Harmonic balancer ? >
Harmonic balancer ?
Harmonic balancer ?
Old 04-04-2009 | 03:15 PM
Default Harmonic balancer ?
will a gen IV and gen V harmonic balancer interchange?
tx911 is offline
Old 04-04-2009 | 05:58 PM
noone knows if I can put a balancer off a mark IV motor on a Gen v motor?
tx911 is offline
Old 04-04-2009 | 06:08 PM
They will interchange but if you are running external balance engine the balance might be off,a balance shop can check your old one and match the new one to it,if needed
MDGperformance is offline
Old 04-04-2009 | 06:16 PM
Thanks for the reply, I will do that
tx911 is offline
Old 04-04-2009 | 06:17 PM
I am 99% sure they have a different balance.
Young Performance is offline
Old 04-04-2009 | 07:11 PM
tx,
I just looked in the new GMPP catalog and at ATI's web site and they both say that they are interchangable.
Bill Koustenis
Advanced Automotive Machine
Waldorf Md
BillK is offline
Old 04-04-2009 | 08:19 PM
Thanks for looking Bill, I should have thought about looking it up.
tx911 is offline
Old 04-05-2009 | 12:47 AM
That damn 1% got me again.
For some reason, I think the casting numbers on the Mk IV and the Gen V and VI are different. They may make different ones but they have the same counterbalance.
Old 04-05-2009 | 03:31 PM
Thoses different ones are between the 502 and 454 Gen VI, the heavier rotating mass of the 502 means the balancer doesn't have a fly cut groove on the outer ring. Other than that, there's only the timing marked in degrees vs just TDC that apparently separates the balancers. They all have the same snout diameter and are interchangeable.
Ghostrider is offline
