How to change antenna battery on a Livorsi GPS speedo?
#53
#54
Batteries plus, at least the one in my town, will not touch this. After getting it apart I remembered this post and decided to go for it. I very carefully broke the soldered tabs loose from the battery with a mat knife blade. The bottom one was the beotch. Be very careful there. Then put a generous dollup of super glue on both tabs and had my wife slide the battery between them while I held a hemostat in place. Lock the hemostat down and let it sit overnigh. Done! $5 bucks!
Reinstalled today and it works.
What a chitty design!
#55
So glad I did a search here before pulling mine. Thank you sir!
The battery makes contact with the super glue on the tabs?
You put the glue on the tabs that touch the battery?
Thanks.
Long time cult member.
#56
This is a very informative post but why does livorsi say that it needs "reprogramming" after changing out the battery? I tried this exact thing except made a "harness" for mine that I could simply plug in a new battery when the old one went dead. Tried and no go.... sent it to livorsi and they said I could have the battery replaced or I could upgrade... I just upgraded...
BTW, while trying to solder the wires on the battery, I learned the "too much" heat is not good... can you say "pop" corn? Holy Crap... I think I unloaded lol
#60
Offshoreonly Advertiser
GPS Livorsi Antennas
I would like to clear the air on everytinng I have read.
Livorsi is offering a NO Battery GPS antenna for half the cost at 169.00. There should be no further battery issues. Visit www.livorsi.com or call one of our distributors. If you have the antenna that connects with a molex connector the best thing to do is send the antena back with the gauge for testing. There are some capatilbility issues with older GPS. We will test to see if it is compatable with the new battery less antenna.
The batteries in these antennas are to hold memory into the GPS so next time you start your boat you dont have to wait 45 minutes to aquire GPS satellites again. They typically last 3 to 4 years just like watch batteries. You know when a battery goes dead, the pointer goes to the 9 o'clock position on the gauge.
The batteries are welded into place and are very diffuclut to get to. They are NOT RECHARGABLE and if you try and recharge them there is danger of explosion. We do not even attempt it at Livorsi. They have to go back to the factory.
