dimension of hydraulic lines for steering >
Old 04-17-2009 | 03:12 PM
Default dimension of hydraulic lines for steering
i want to renew my hydaulic lines for steering. i had 8 mm (0,32 inch) lines and i found out that there was a bypass where the line is reduced to 5 mm (0,2"). a mechanic told me at car steerings it is common to use such bypasses in the pressure line.
my question: does such a reduction make sense in the hydraulic steering of a boat? I have 2 imco rams and a charlyn helm. Pressure comes from the stock chevy power steering pump. is it better to use 8 mm or 10 mm lines. (0,4")
thanks for your help.
chris
chris-jack is offline
Old 04-17-2009 | 03:28 PM
Default Line Size
Your Line Size Should Be 10mm Or Here In The Us 3/8
Jb-fse is offline
Old 04-18-2009 | 12:34 AM
...without any reduction?
Old 04-18-2009 | 12:48 AM
Si, Senor! Or -6....5/16"
AO31 is offline
Old 04-19-2009 | 02:32 AM
5/16 is like our 8 mm line. this was the dimension installed. and it also had a reduction just in front of the filter.
chris
look at this: http://www.offshoreonly.com/forums/g...-steering.html
