Way OT, But need help with my Banshee >
Old 03-23-2002 | 12:03 AM
Bruce
The pilot typically controls the idle circuit and just off idle. If the engine doesn't respond to the neddle changes, check your ignition timing again. The info provided about the needle is correct and should help your transistion, if it doesn't verify your timing.
Old 03-23-2002 | 03:54 AM
I had to read your post twice but FMF told you to change pilot to 30, then I would do that first with needle centered, and then adjuct clip position. Pilot is amount of fuel and needle taper dictates how much and how quick. DON'T RUN LEAN Properly jetted midrange builds alot of tork. Good luck
Geo 100 is offline
Old 03-23-2002 | 10:09 AM
CheckmateF1's Avatar
Charter Member #355
So what's up Hi-Perf? Did that help?
Eric
CheckmateF1 is offline
Old 03-23-2002 | 10:45 PM
HiPerf2000's Avatar
Raising the Needles WORKED!!! It still backfired slightly until i fine tuned the fuel/air mix....Then it ran much better!! FMF also said to run without the airbox lid snorkel...so instead of the 1-1/2 inch round opening for the airflow, you have an oval 4 x 1 inch opening that flows much more air. This kept me a bit lean...so i ended up (don't laugh) duck taping half of the airflow opening to make it 2 x 1 inch. This cut off some airflow and richened me up! I know it's probably not right, but it's running great, so i'm leaving the duck tape...i may just get a black marker and color the tape to make it match the airbox
Thanks for all your help
HiPerf2000 is offline
Old 03-24-2002 | 01:10 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
Thay make black duct tape.
Sydwayz is offline
Old 03-24-2002 | 07:17 AM
NASTY HABIT's Avatar
can you just drill some holes in the lid..... glad you got it worked out.. those problems can be a real b$%@&...... have been tinkering on a turbo bike that is running rich for the last few weeks.. i think it's time to yank that s&s off of it and get a mikuni
NASTY HABIT is offline
Sydwayz
Active Thunder
27
07-12-2023 10:28 AM
Dredgeking
Active Thunder
7
07-11-2023 02:32 PM
LapseofReason
02-21-2004 07:11 PM
eatonn
Active Thunder
9
11-29-2003 07:59 PM
