Direction of 496 Impeller? HELP!!!!
No problem! I just replaced the impeller on my 2002 496 on Thursday, so it was still fresh in my mind how it looked when I took the pump apart. Lucky for me it was still in one piece. If your impeller was that bad you should probably back flush your cooling. Any broken impeller pieces can get stuck anywhere in your system (oil cooler, fuel cooler, exhaust, etc.) and could cause problems down the road.
Yes, I actually bought 'Dawn' dish washing liquid today, but then someone else mentioned vasoline. Seems like vasoline, used sparingly would provide longer lubrication, but I agree that it wouldn't wash out like dish soap. I'm going to fire up the motor right after I'm done, so probably no risk of the soap drying up.
Thanks!
Thanks!
Ken
I bought the water pump rebuild kit from the R&R guys. Too many grooves in the cup and backing plate. Seems they have a pretty good solution.
http://www.randrproducts.net/product...waterpump.html
