Shifter hard to move..Bravo 1
There is always a possibility that the shift shaft is bent. If it was shifted aburtly or forced into gear when it didnt want to be shifted.. the shift shaft could be bent and binding... Just another thought.
MnFastBoat, How the heck are you?? Been a while! And yes we covered this a long while back..
Dick
Dick
Dick
Dick
This Cat is trying to keep up with the Big Dogs
I blew my drive the first time out this year a couple weeks ago. I just installed a brand new XR and replaced the lower shift cable. The shifter works like butter now. The original lower shift cable was shot.. Thanks for all the help...Jeff Wurl
there is a detent ball that was my problem
No reason to pull drive for this, if its a Bravo, not sure about others.
Bravo one, rear facing cover, pull off, will loose some fluid
