New Restriction: 80 Decibels - Lk Mntka, MN >
Old 04-30-2009 | 06:18 PM
NoQuarter
Originally Posted by Griff
Get the exhaust leagal and then upgrade the stereo so it runs at about 130db.
80db is nuts. A gas powered weed eater is louder than 80db.
A Fiat is 82! JC!!!
Old 04-30-2009 | 06:21 PM
NoQuarter
Originally Posted by Plum_Crazy
Where did you hear/see this 80dB limit? The MN state limit is 84dB at idle. Can Lake Minnetonka define its own limit?
After much arguing, Yes. Something with the Fresh Water Preservation... something or rather.
Old 04-30-2009 | 06:41 PM
hp500efi's Avatar
Member #9
Originally Posted by RMPRam
I'm in full agreement with Audio. It is up to us, whether we like or not. Be proactive. As you can see, I am. The system works! Under 80db at idle, keeps the "noise" between the drives and points it down.
That is only a solution for slow no wake. How is it on plane?
Member of the Liquid Jungle
hp500efi is offline
Old 04-30-2009 | 07:52 PM
Audiofn's Avatar
Charter Member #232
Even on plane it will help a LOT. The water is all turned up and the exhaust is aiming into that. It is a natural absorption area for sound. The one pictured probably works even better because it is contained some what between the drives as well.
Put your best foot forward!
Audiofn is offline
