lost coolant >
lost coolant
lost coolant
Old 05-13-2009 | 11:15 AM
sdfever and raeburn you both have raylar heads,,,what raylar have to say about this???could it be tha heads bolts that come with the kits??,,,?raylar
TWIN-SPINS is offline
Old 05-13-2009 | 05:10 PM
Originally Posted by SDFever
Hate to hear it but I thought I was the only one. Drives me absolutely ph_cking nutz!!!
I've had the exhaust off 4 times now trying to get it to stop. Same for me 2 & 4 on port side.
Total, utter
What heads are you running stock ones or ???, A few things come to mind when thinking about this maybe the bolts are under torquet, Or have been over torquet and now the head bolts are streched out not doing there job, Or maybe the head gasket is weak in that area when the head gets real hot. Or maybe after A long hard run maybe the heat is expanding one of the materials used in that area like either the head to gasket area, Or the head bolt Holes Area are expanding when hot and under pressure making them leak with in combo of the bolts not tight enough with head gasket used. Mayby next time you are out playing around on the boat you should take your infa-red temp reader gun and test it at warm up and then after a long run and see how hot the bolt area gets just to see. Just some thoughts for you but i'm sure you have done that your self. Good luck with it.
Boat Tech is offline
Old 05-13-2009 | 11:51 PM
This is not the issue but I agree with you. You have to consider every possibility.
SDFever is offline
Old 05-17-2009 | 08:43 AM
boatingbent's Avatar
I just got mine back about a month ago ...My heads leaked and they are Raylar heads...And the leak was coming from 2 of the head bolts
boatingbent is offline
Old 05-17-2009 | 11:48 AM
You said "was"... Sounds like you fiixed it. Please share what you did.
SDFever is offline
Old 05-17-2009 | 03:54 PM
I really don`t think I wanna tell the story on an open forum I am just way to nice of a guy....
Old 05-18-2009 | 11:12 AM
Originally Posted by Westcoast
My guess is the shop that did the service got it hot at some point and you lost some fluid when it overheated. It sure would have been nice if they would have at least topped it back off for you.
You're just glad Paul doesn't read much of this stuff.
SDFever is offline
Old 05-18-2009 | 07:27 PM
Why did he work on it?
Westcoast is offline
Old 05-18-2009 | 08:56 PM
you lost me. i didn't get it...
SDFever is offline
Old 05-19-2009 | 12:58 PM
are they still leaking or is there a fix,,, with 500 kits out there what gives???
