Low seawater pump PSI? >
Old 05-08-2009 | 06:23 PM
Registered User
Exclamation Low seawater pump PSI?
Mer 350 MAG MPI Tow sport package
seawater pump 1.69-1.98 psi w/ brand new pump installed.
could this be from a bad w/p hsg? or just a low pressure system? Tige boat yr is 03 and motor is hooked to a v-drive with a water pickup on the under side of the boat.
Cody-
FasterThanU87 is offline
Old 05-08-2009 | 09:02 PM
Cody-
Is that at idle or what rpm do you get that reading? Normaly it will read any where from .3 up to 2.0 psi depends on idle speed and how much water pressure you are pushing thru the system while on the garden hose, If you rev it up it needs to go up around 17.5 or so psi while on the lake, But make sure it goes up on the hose as well to 5+psi while reving. And do not put yours in gear while on the hose.
Boat Tech is offline
Old 05-09-2009 | 01:45 AM
Run the boat in the water to find out actual water pressures.
Griff is offline
Old 05-11-2009 | 11:40 AM
Registered User
thanks boat deck, an yea it was like 4.7 psi at 2500 RPM so it did move up when i gave it more throttle but sorry griff i couldn't really do that because it was a customers boat in my shop an its not always easy to make it to the water to test them on a friday but it all worked out thanks guys
Old 05-11-2009 | 12:58 PM
Trying to duplicate water psi readings running on the hose does not work.
Griff is offline
