Dart block lifter question >
Old 05-21-2009 | 12:58 PM
lake speed's Avatar
Default Dart block lifter question
I have a new motor going together and the foundation is a new dart 10.2 deck block. the problem is that I have comp cams hydraulic roller lifers with the vertical tie bar and it bottoms out on the lifter block. anyone have this problem. I have another set of isky lifters and they do the same thing. does the block need machined in this area or does someone know of a set of hr lifters that will work
lake speed is offline
Old 05-21-2009 | 01:46 PM
You need something like this. They are .300 taller than stock.
http://store.summitracing.com/partde...6&autoview=sku
I have a friend who ran short lifters in a Dart block. One of the link bars broke off and caused some significant damage.
tjsmk8 is offline
Old 05-21-2009 | 01:52 PM
lake speed's Avatar
I spoke to my builder and he says that the lifter bosses can be machined to run the shorter lifters?????? wouldnt the rocker arm geometry be screwed up?
Old 05-21-2009 | 02:05 PM
No all you need to do is mill .300 off the front of the lifter boss in the block, so the tie bar will clear it.
dennis r is offline
Old 05-21-2009 | 03:46 PM
No, it will not affect the geometry as long as you get longer pushrods. If you do not have them already, then no big deal. You will still need to mock it up to get the correct length pushrods.
Eddie
Young Performance is offline
Old 05-21-2009 | 06:56 PM
lake speed's Avatar
I have comp 7141 and 7131 pushrods. I ordered the .300" lifters. are these pushrods going to be too long since they were in my other motor? it was a 10.2" bowtie block and it had the standard height lifters. I know have a 10.2 deck dart block with .300" lifters. the tech guy at comp said that the pushrod length should be the same as the only difference is the actual body of the lifter and the plunger is the same height?????????/ I guess I will get my trust pushrod measuring tool out tomorrow. damn I am tired of problems.
Old 05-21-2009 | 07:01 PM
You won't know until you mock it up and check the rocker geometry. Just have to check them and see.
jeff1000man is offline
Old 05-23-2009 | 05:33 PM
lake speed's Avatar
well I went from comp lifters to comp .300 taller lifters so i was assuming that my pushrods would be too long................... thats what happens when you assume. the new lifters have a taller body but the plunger is farther down inside the lifter so the pushrods were actually too short.
