kill switch wiring >
kill switch wiring
kill switch wiring
Old 03-26-2002 | 08:33 AM
Default kill switch wiring
Anybody out there know how to wire the two wires to my kill switches.Thanks
fishead is offline
Old 03-26-2002 | 08:45 AM
Ted G's Avatar
What type of engines??
www.cbpba.com
Ted G is offline
Old 03-26-2002 | 12:16 PM
small blocks
fishead is offline
Old 03-26-2002 | 01:11 PM
Mbam's Avatar
Offshoreonly Advertiser
What kind of ignitopn, what kind of kill switch?
Mbam is offline
Old 03-26-2002 | 03:52 PM
MSD ignition with the 6al-m box.The kill swithces are black spring loaded buttons with caps on them they have a green wire and a black wire.
fishead is offline
Old 03-26-2002 | 04:00 PM
blown formula's Avatar
It matters if your kill switches are normally open or closed. My Formula is a normally closed type switch. The hot wire to the ignition switch comes from the circuit breaker thru the kill switch to the ignition switch. The kill switch here is held in the normally closed position, so pull the cord & 12 volts disappears from the switch. I saw another post where someone with a normally open type switch ran a ground wire to the switch and then from the switch to the coil. Personally, , I prefer to remove the 12 volts rather than ground a hot lead.
Either method should work. (this is per the Formula wiring diagram faxed to me today by Formula). Your manufacturer may do the same. Good luck !
blown formula is offline
Old 03-26-2002 | 04:38 PM
Mbam's Avatar
Blown Formula explained it well, the only thing I can add is that if it is a grounding type switch do not use it to ground the coil on that MSD. You could try using it to short the mag pickup wires.
Mbam is offline
Old 03-26-2002 | 08:00 PM
Thanks guys
fishead is offline
Old 03-27-2002 | 12:08 AM
Audiofn's Avatar
Charter Member #232
Also make sure you have extra caps on board. If god forbid you ever go over the only way for they people still on board to get back to you is with a second set of caps
Jon
Audiofn is offline
SkiDoc
10
05-16-2021 09:54 AM
Fenderjack
0
08-30-2007 03:25 PM
p4-33
General Racing Discussion
1
05-17-2003 04:36 PM
p4-33
1
05-15-2003 11:56 PM
sheikman
1
05-27-2002 09:45 AM
