blower mtr timing >
blower mtr timing
blower mtr timing
Old 05-24-2009 | 03:20 PM
Default blower mtr timing
why is it so popular to lock out the timing on blower mtrs?
tomcei is offline
Old 05-24-2009 | 03:31 PM
jdnca1's Avatar
They start better for one, and IMO it helps take the surge away...
jdnca1 is offline
Old 05-25-2009 | 02:23 PM
well you only want about 26 of total timing, locked will clean up the idle and with very low compression starting usually not a issue..Rob
ezstriper is offline
Old 05-25-2009 | 02:40 PM
jdnca1's Avatar
I run 32 degrees timing, have for years. 8.5-8.75:1 static, starting has never been an issue.
jdnca1 is offline
Old 05-25-2009 | 04:22 PM
Strip Poker 388's Avatar
Rob
I was told and found out that Low timing at idle, to off idle exhaust temps go thru the roof ,hot enough to stick a ex valve in the guide even up to .0025 clearance,That motor was locked out at 36.
My 500efi Whipple map totals out at 36.
Strip Poker 388 is offline
