Helm and Trim Pump Fluid >
Old 05-28-2009 | 01:27 PM
CcanDo's Avatar
Default Helm and Trim Pump Fluid
Opinions needed for best Helm and Trim pump fluid.
The trim pump placard states 10w40 motor oil. However,we have seen corrosion in pump resevoirs after using 10w40 motor oil.
The helm instructions state Dextron III. However,not only can that be a slow fill, it can be a challenge to bleed.
Therefore,if type F transmission fluid has been found to work/ not work for either or both of the applications your comments would surely be appreciated.
CcanDo is offline
Old 05-28-2009 | 01:29 PM
ATF
DareDevil is offline
Old 05-28-2009 | 01:41 PM
CcanDo's Avatar
daredevil, Thanks, but what formulation of ATF ?
My thought is that if ATF is to be used for both, Type F may have better anti-foaming properties and seal lubrication than other automatic transmission fluids.
CcanDo is offline
Old 05-28-2009 | 02:05 PM
Default This Is Out Of Our Eaton Products Catalog
Atf Type A And Most Petroleum Based Fluids
Jb-fse is offline
Old 05-28-2009 | 02:23 PM
How about a 5wt or 10wt hydraulic oil?
It has all the stuff for seals, additives to fight rust, foam and wear, and it is available everywhere.
Personally I have 5wt fork oil in mine.
Ken
minxguy is offline
Old 05-30-2009 | 01:09 PM
CcanDo's Avatar
CcanDo is offline
