High Idle on 525 >
High Idle on 525
High Idle on 525
Old 06-08-2009 | 11:52 AM
Gladhe8er's Avatar
Default High Idle on 525
Revved up my engine to about 2300 RPM at the dock and I heard a "pop." Now the engine likes to idle at 1200 RPM instead of the 720-750. When I throw it in gear, the revs drop back down to 720-750. Obviously its not good to slam the boat into gear with RPM's at 1200. What do you think happenned?
Gladhe8er is offline
Old 06-08-2009 | 05:05 PM
same engine, same problem. No problems last year but now when i come out of the throttle back to idle its about twice of what it should be. Docking becomes a real PITA!! Some times i can get it to come back down with a couple quick jabs on the throttle.
dzglaser21 is offline
Old 06-08-2009 | 06:02 PM
Check the throttle linkage. Mine came loose and if I remember correctly, that's what it did. See photo of the bolt that came loose on mine not allowing the throttle to come home. Don't overtighten it either, it will bind.
raytart is offline
Old 06-08-2009 | 06:59 PM
Running a Bravo drive? You're close to locking up the clutch cone at those rpms.
MacGyver is offline
Old 06-08-2009 | 09:14 PM
Gladhe8er's Avatar
Thanks. I will take a look.
Originally Posted by MacGyver
Running a Bravo drive? You're close to locking up the cluch cone at those rpms.
I dont know what that means, but it doesnt sound good.
Old 06-08-2009 | 09:15 PM
Gladhe8er's Avatar
I can get it to come back down sometimes too. If I cant, I usually shut the engine off and restart...sometimes that helps.
Old 06-08-2009 | 10:21 PM
Working on this same problem. I was told that it is a TPS sensor, the sensor needs to be adjusted to the proper voltage. Since the TPS is out of adjustment at idle the computer calls for what power is requested at the apparent voltage.
mike38scarab is offline
Old 06-09-2009 | 12:22 AM
Please keep us posted on this and what the fix is.
Old 06-09-2009 | 12:27 PM
Gladhe8er's Avatar
yes, please let us know how this turns out and how much of a pain it is to fix.
Old 06-09-2009 | 07:25 PM
When you shift into gear above 1500 or so, the clutch cone likes to lock-up. Open up your checkbook to fix
MacGyver is offline
