Risers?
Old 06-10-2009 | 05:36 PM
Originally Posted by Ghostrider
Remember: Loud Boats Save Lives!
Priceless!!!!
I thought I was the only one that said that!!
So I would assume the long risers, where the water introduces right at the end of the riser, increases the decibel level by 10db +/-3??
ittledoo is offline
Old 06-11-2009 | 07:49 AM
Wouldn't have a clue!
I just like loud boats!!
Ghostrider is offline
Old 06-11-2009 | 07:55 AM
Originally Posted by jeffswav
Good risers should have a 4" outer diameter with at least a 3.5" inner diameter. The water travels through the exhaust and keeps it cool then exits at the end. The riser fits on top of the manifold. Take a look at some manufactures websites. Eddie Marine, Imco, Stainless Marine, maybe that will help.
Risers are a combination of height and diameter. The best sort would be the high rising long tail length ones as they would have the highest flowing bend and the latest mixing exhaust and water, but they don't always fit under your hatch (as I found out the hard way), the next best ones would be the low rising bend with the long tail pipe which still has a smooth bend with less rise and the long tail pipe helps stop the water getting back up the exhaust passage and into the heads as it mixes further away.
Heres some pics: (the green ones are cast aftermarket EMI Risers, don't laugh, I think they look great! )
Thanks guys it all makes sense now. It was the term riser and talk of diameter in the same sentence that was throwing me off.
NoWake200 is offline
Old 06-11-2009 | 07:57 AM
Could it be that there is less back pressure... smoother exhaust flow of the aftermarket header creating the increased db.
Just my thought.... probably wrong.
Old 06-11-2009 | 05:20 PM
Well, I thought that the purpose of mixing the exhaust w/ the water is what muffles the noise. So if there is less muffled, inverse on the noise.
The only reason I bring up that issue is there seems to be more and more lakes going to a db level rule.
ittledoo is offline
Old 06-13-2009 | 11:30 AM
I though the mixing was for cooling. But like always... I am probably wrong.
May be someone in the know can shield some light.
And the db level laws are crAAp in my book!!!!
Old 06-13-2009 | 12:55 PM
That is why the exhaust have a inner and outer tube. The water keeps the exhaust cool. If you have db laws get mufflers, or switchable muflers.
jeffswav is offline
