Water Pressure Guage >
Old 06-10-2009 | 01:06 PM
Default Water Pressure Guage
I mixed two subjects in a previous post and got not response to this portion.
Where is the best place to put a water pressure sensor in a Gen IV 454? Will a sensor in the intake manifold suffice?
Scott
GSELITE2000 is offline
Old 06-10-2009 | 01:27 PM
water pressure should be constant throuh the block with slight variation. most take the pressure off of any one of the plugs on the side of the block but the intake manifold would work i suppose.
stevesxm is offline
Old 06-10-2009 | 09:14 PM
Throttle Fever's Avatar
I run mine off the back intake. Were the water bypass ports are in the manifold, by the distributor. Works great and they do not get clogged up like they did when they were down on the block...
Throttle Fever is offline
Old 06-10-2009 | 09:16 PM
If you have a place to take it from the intake, that will work fine and won't clog as easy as using the block drain hole.
Griff is offline
Old 06-10-2009 | 09:26 PM
Default Thanx...
for the replies.
I will check all the suggested locations.
Scott
