Whippled 525 EFI >
Whippled 525 EFI
Whippled 525 EFI
Old 06-17-2009 | 07:32 PM
Default Whippled 525 EFI
I have a pair of Whippled 525 EFI motors that I am getting freshioned up at a very reputabil shop. When it is all said and done the motors will have a complete over haul minus the cam(he said didn't need) it will be .060 over with new JE pistons running about 6-7 lbs boost, he thought 740-775 HP on dyno. My issue is I want to get rid of the closed cooling system but I want to run a thermostat. I was told to do this we would need to reenvent the wheel. I wave a pair of cross overs with the pullie to keep my surpentine belt but still no thermostat. I am scared that no thermostat will affect the fuel curve since the water in Iowa doesn't warm up until July- August. He said he could change the computer to do what ever we need. Which is the best way to go here?
ozarkdevil is offline
Old 06-17-2009 | 09:35 PM
Smitty's Avatar
What is your specific reason for wanting to get rid of the closed system?? Is it not doing what you need it too???
Smitty is offline
Old 06-18-2009 | 09:24 AM
I'd leave it on.....nothing like
being a guenea pig.
How do you plan on dealing with the different
coolant routing these things have ?
JaayTeee is offline
Old 06-18-2009 | 01:33 PM
x2. Leave it closed cooling and spend the money and time on some other part of the boat. Can't you just put a t-stat in under the water neck in the manifold? My crossovers have t-stats. If you're worried about the exahust, drill a couple small holes in the t-stat and be done.
niceguy is offline
Old 06-18-2009 | 01:58 PM
There isn't a water outlet on the manifold in the
traditional sense, there is an outlet on each end
of the cylinder head.
http://www.mercruiserparts.com/Show_...sed+Cooling%29
http://www.mercruiserparts.com/Show_...28Sea+Water%29
JaayTeee is offline
Old 06-18-2009 | 02:58 PM
Ahhhhh, thanks for clearing that up for me. Then I have no solution.
niceguy is offline
Old 06-20-2009 | 12:21 AM
It was suggested by the motor builder and I don't see any real advantage to a close cooling system running in fresh water. It will also make the motors look nicer.
Old 06-20-2009 | 12:23 AM
The biggest issue is finding a crossover to use with a serpentine belt, that I can afford. I did find a pair but at just under $2200.00 I need a different idea.
Is it possible to remove the impeller from a stock water pump and use it as a crossover? It already has a pulley on it that I need. Has anyone ever tried this?
Old 06-21-2009 | 11:40 AM
JasonSmith's Avatar
Someone makes a cheaper alternative. I have the link on my laptop at the office. I'll get it for you tomorrow.
JasonSmith is offline
Old 06-21-2009 | 03:28 PM
Thanks!
So my brain storming idea to remove the impeller from a stock recirculation pump and use it as a crossover with the pulley isn't such a good idea after all?
