Drive Trim / Tilt help! >
Old 06-24-2009 | 01:29 AM
Question Drive Trim / Tilt help!
Okay, Rookie question:
My drive trim / tilt doesn't go up. The trim works to go down, but it doesn't work to go up, the trailer tilt switch doesn't work in either direction.
Is there a simple check to diagnose?
I tried jumping the blu/whi to the hot side of the relay and nada. I tried putting it straight to the power terminal between the solenoids and nothing. I am now limited in creative ways to check! HELP!
Oh, I disconnected the trim sender and trim limit switch as I didn't plan on using it. Is that the cause of my problem? Or do I have a shot relay?
As always, your help is greatly appreciated.
Ghostrider is offline
Old 06-24-2009 | 06:43 AM
Audiofn's Avatar
Charter Member #232
If you jumped across the two larger posts on the relay you either have no power at that relay (test with a test light or volt meter) or you have a bad pump. The pumps care (rarely) go bad in one direction. Make sure you have power at the relay first.
Put your best foot forward!
Audiofn is offline
Old 06-24-2009 | 04:14 PM
Do I have to connect the trim limit switch (not connected) to anything to make it work?
Old 06-25-2009 | 09:09 AM
Wally's Avatar
Were doomed!
easiest thing to do first to verify you have a good motor on the pump is to dissconnect the 3 pump wires (green/blue/black) and hook them straight to power...black is ground the two others are up/down (blue=sky=up green=grass=down) if the pump works then go from there. You should have a decient volt meter for testing things...test lights can give out false readings when there's back feed sometimes....
-Wally
Wally is offline
