How Heavy And Will My Truck Be Ok. >
Old 06-27-2009 | 12:03 PM
Default How Heavy And Will My Truck Be Ok.
Im getting a 1986 four winns 261 liberator with twin 350's my question is how heavy are these boats? I have a 1999 f-350 crew cab dually diesel that i know will pull it with no problems my issue is its 2wd how will that do pulling up the ramp?
big99diesel is offline
Old 06-27-2009 | 03:21 PM
I would suggest you try the Truck and trailer forum. The boat is probably a max of 8500 lbs. Your truck will handle that no problem. Is your hitch rated for that much? If your launch ramps are clean (no seaweed, algae) 2wd is OK.
Good Luck
Wannabe
wannabe is offline
Old 06-27-2009 | 04:40 PM
yeah i got a hitch that i used when i pulled 18000 lbs so that will be ok and the ramps where im gonna drop the boat are always clean and dry
Old 06-27-2009 | 08:50 PM
7200-7500lbs, wet on trailer(gear for weekending can add substantial lbs.)
Make sure you have @ least 10% tongue weight, actually 12-15% will help w/traction.
2wd should be just fine; keep good rubber on there
spilman is offline
Old 06-28-2009 | 07:57 AM
birdog's Avatar
I towed my lib with a 2wd Dually. I always kept a couple empty plastic 55 gallon drums in the bed in case i ever needed traction for slick ramps {just fill them with water}
Never did need them though..Even at Cumberland with the straight up ramps
birdog is offline
