Do I need a bigger oil cooler.... >
Old 06-27-2009 | 05:00 PM
Default Do I need a bigger oil cooler....
Just left the river and I wrote down all my readings from today.
This is a 1989 Pachanga 22 with a "new" 20 year old 454 (It sat in storage for 15 years with 5 hours on it. It now has 10 hours on it.)
So obviously Gen IV, and it is stock except I got rid of the circulating pump and put the bypass stuff on it. This engine has the stock small oil cooler under the right exhaust.
At 3500 RPM, I have 9 PSI water pressure, 130-135 water temp, 50 PSI oil pressure, and 230 oil temp (oil temp is taken at the oil filter housing on the side that comes directly to the filter prior to going through the cooler).
Is this oil temp too high?
Scott
GSELITE2000 is offline
Old 06-27-2009 | 05:34 PM
Strip Poker 388's Avatar
Rob
Scott
Water presure seems low, ck as see if any impeller parts or trash is in the cooler and ck the drain cock in the block see if full of sand etc. you never know.230 is worm on a stock motor.Is it over proped? lugging it? my 2 cents worth
Strip Poker 388 is offline
Old 06-27-2009 | 05:44 PM
Default Not over propped.
Running a 21p, and it tops at right at 44-4500.
Sea Pump just rebuilt, plus the water temp is plenty cool.
I thought that I read on these OSO threads that the pressure should be around 12 PSI in the 4000s. Just means good volume.
I just don't think the oil temp should be that high.
Scott
Old 06-27-2009 | 11:17 PM
Audiofn's Avatar
Charter Member #232
What HP 454? Stock or mofified? That does sound like high oil temps to me. What oil are you running?
Put your best foot forward!
Audiofn is offline
Old 06-27-2009 | 11:42 PM
Default 330 horse....
not modified. Just had the engine installed, don't know what oil they put in it.
Scott
Old 06-28-2009 | 09:54 AM
Rage's Avatar
Make sure that your oil temp gage readings are accurate.
Rage is offline
Old 06-28-2009 | 10:30 AM
Old 06-28-2009 | 04:40 PM
230 is on the high side, but not really an issue. My thought is to wait unto you have 20-25 hrs on the new engine and see if you oil temps don't drop from your 230 degrees @ 3500 RPM.
BenPerfected is offline
Old 06-28-2009 | 05:13 PM
offthefront's Avatar
1) Make sure the oil temp is correct .....
2) If it is correct I would make sure you run Synthetic oil ...It tends to hold up better to high temps ....
offthefront is offline
