Hydraulic Lifter Noise >
Old 07-05-2009 | 10:13 AM
Default Hydraulic Lifter Noise
Tall Deck 598 crane hydraulic vertical bar lifters. After a hard run, when I pull back to idle I have one very noisy lifter. Is there a way to figure out what lifter is making the noise without changing all of them?? Because the lifter pumps make up in 1 minute. I'd like to change 1 lifter instead of all of them. I have adjusted them 3 times already with no success. I bought 2 lifters if needed. Any help would be great!! Thanks- Joe
joepequa is offline
Old 07-05-2009 | 10:16 AM
Panther's Avatar
Frank's Marine Service
Screwdriver or solid piece of metal pressed against the valve cover and your ear should help you to locate on/near the loud lifter. Since you have two of them, when you find the area you can replace both lifers in that space.
Panther is offline
Old 07-05-2009 | 07:38 PM
Angry
noisy lifter
joepequa is offline
