Carb size?
Old 07-31-2009 | 09:49 AM
Default Carb size?
I have a 7.4L 300HP carbed motor. I'm changing the carb out, what size holley 4150 should I use and what size jets? Also changing to a air gap intake on recommendation from OSO. Thanks in advance!
footchopper is offline
Old 07-31-2009 | 11:20 AM
750cfm
Griff is offline
Old 07-31-2009 | 12:45 PM
Wobble's Avatar
SORE MEMBER
look into barry grant sea demons, had very mixed results with holley marine carbs.
In fact I would recomend calling their tech line for a size recomendation.
http://www.barrygrant.com/demon/default.aspx?page=21
Wobble is offline
Old 07-31-2009 | 04:34 PM
I agree with Griff. Anything more than a 750 will be too much for that motor.
Sledge Hammer is offline
Old 08-01-2009 | 09:30 AM
Wobble's Avatar
SORE MEMBER
The reason i suggest calling tech is that Demon carbs are wet flow rated and therefore do not directly compare to holley numbers.
Wobble is offline
Old 08-01-2009 | 04:52 PM
Strip Poker 388's Avatar
Rob
thats like there fuel pumps are like 15 volts
The holley 4779 would be a good one,or the new version of it, or the BG speed demon,just order the j tubes or order them from Gary Williams carburetors,mississippi,he also sell carbs.
The BG seems cheaper than the Holleys,last time i shoped them.
A 4 corner idle will be better
http://www.barrygrant.com/demon/default.aspx?page=5
http://www.jegs.com/i/Barry+Grant/13...010VE/10002/-1
http://www.summitracing.com/parts/HLY-0-4779C
droplegs, hp version
http://www.summitracing.com/parts/HL...1/?image=large
if your planing on moving up in power in the future, step up to 850+
Strip Poker 388 is offline
