head choices >
head choices
head choices
Old 08-02-2009 | 04:47 PM
Default head choices
Thinking about putting some aftermarket heads on my 500efi any thought about what use ? try n to make 600 to 650 hp . Im leaning towards the afr 305s but im open to ideas
innovator1 is offline
Old 08-02-2009 | 10:55 PM
are you looking for the best out of the box or are you going to have them ported?
i recently ordered 2 sets of dart pro 1's 310cc. with the right cam, comp. etc you should be fine with minimal work. can get you some dyno sheets if you would like.
john
[email protected]
getrdunn is offline
Old 08-03-2009 | 08:57 AM
That would be great! Im running a comp cam now here are the numbers @ 50 236 - 242 duration 606 - 613 lift with a 114 lobe seperation
Old 08-03-2009 | 09:08 AM
on a 500EFI dont forget fuel regulars, bigger injectors, re-mapping computer and a few other things when looking for 600hp and alum heads...
Boomer35 is offline
Old 08-03-2009 | 09:19 AM
Thunderstruck's Avatar
500 EFI intake is very restrictive. 600 HP with the stock intake is tough. I believe a 500EFI with AFR 305 cc heads and a good cam made ~575 hp.
Long time cult member.
Thunderstruck is offline
Old 08-03-2009 | 09:23 AM
intake and and the throttle body
Boomer35 is offline
Old 08-03-2009 | 01:33 PM
already have 48 lb injectors along with a adjustable regulator. whats the down fall of the intake the upper or the lower ?
Old 08-03-2009 | 01:39 PM
thats exactly what i went to, the 48lb injector with press regular, (that is nearly impossible to get to in a cramped twin eng 30' cigarette)
Boomer35 is offline
