Oil Filter Update >
Oil Filter Update
Oil Filter Update
Old 08-08-2009 | 07:08 PM
  #31
Cant find filter replacement for WIX or Fram HP 6 !!!!!!
AMSOIL HELP ????????????????
DareDevil is offline
Old 08-09-2009 | 12:23 PM
  #32
Rebel_Heart's Avatar
If I am running 540s, 700 hp. Change the oil and filter once per year, 20-25 hours. Do you still recommend Amsoil or Mobil 1? Or, should I keep using the Wix Racing filter?
Planning on moving from racing Valvoline 40 to Mobil v-twin oil. If this makes a diffenence on filters? Thanks.
Rebel_Heart is offline
Old 08-09-2009 | 05:57 PM
  #33
2112's Avatar
Originally Posted by Hydrocruiser
What type of engines?
604 inch fords, naturally aspirated.
Swapping out HP6s at 10 hours and complete oil change at 20.
I am not criticizing your break down of filters at all. Just from my perspective, I want flow #1, Big stuff filtered #2, Little stuff #3.
2112 is offline
Old 08-09-2009 | 07:21 PM
  #34
Hydrocruiser's Avatar
Arrow
700 HP engines...stick to what you are using I would think....maybe sacrificing some folw for siltration is better to be on the safe side. How often to you freshen the engines.
Here is what I have been finding out....
25% of folks use something like a Wix Racing 1060R/Fram Racing (especially on bigger engines).
25% go with the Mercury HP Racing
25% go with a filter that is basically a synthetic fiber 10 micron filter
25% go with an "off the shelf filter"...paper filter ...
Hydrocruiser is offline
Old 08-09-2009 | 08:10 PM
  #35
I won't freshen for approximately 200 hours. Or, until I see a loss of power. I have about 50 hours on them now.
So you are saying stay with the Wix Racing Filter? Using in conjunction with Valvoline VR1 currently.
Old 08-09-2009 | 08:39 PM
  #36
Arrow
Wix Racing & V-Twin if you can spend the $$.
Old 08-09-2009 | 08:40 PM
  #37
Arrow
http://fram.com/oil-filters/xtended-guard.php
New filter...no info but the add.
Old 08-09-2009 | 09:50 PM
  #38
aTX427's Avatar
Hydrocruiser, what do you recommend on the 700sci? I was told the Wix 57003R was the OEM for Mercury. They are $120 shipped for a case of 6 vs. $65 ea. from the dealer.
Mercury also recommends Kendall GT1 racing 20w50 in the 700sci and specifically says not to run a synthetic. Is the Kendall oil any good and why not run a snythetic?
aTX427 is offline
Old 08-10-2009 | 09:20 AM
  #39
Arrow
Sounds like you have the right filter. If I had that engine I would compare oil pressures with the WixR and Amsoil Eao....if there was not a pressure drop I would personally use the EaO. That's just me... Kendall GT-1 Racing is a great oil.
Not sure why Merc does not use synthetics as many big engine builders do.
If the concern is that there is a myth? fact? that synthetics do not protect metal after
shutdown and corrosion may occur...motorcycle oils are extremely corrosion resistant.
It may be why many like M-1 V-Twin?
Old 08-10-2009 | 09:57 AM
  #40
Default Wix filters
I have used the wix 57003R / with Kendall GT1 20w50 on my 2009 600 sci for 75hrs and no problems , I change oil every 15 hrs for cheap insurance .
wellcrafted is offline
