Fuel Rail Question Help >
Old 08-21-2009 | 10:06 AM
Question Fuel Rail Question Help
Hey guys,
I need to figure out what piece i lost in my current rebuild.. Its a Gen VI 502.. I'm missing a piece thats on the back of the fuel rail and the fuel line attaches too.. Ive ripped my garadge apart trying to find it but i dont even remember what it looks like. if anyone has any pics of it or a part number so i can order a new one.. Thanks guys.
Greek81 is offline
Old 08-21-2009 | 12:11 PM
Heres where my confusion comes in... The back of the fuel rail has 3 holes, top and bottom hole are for a fuel line and the middle is for a screw.. I have only one fuel line with a screw attached coming up from my fuel pump/cooler... Does one of the holes stay open? I dont remember removing 2 fuel lines from the back of the fuel rail or is there a block off plate that i'm missing?
Greek81 is offline
Old 08-21-2009 | 12:20 PM
Advantage 27's Avatar
You should have the cool fuel which I believe the fuel pressure regulator and return is connected to the fuel cooler and only one line going to the fuel rail.
In older 502 efi's there were two fuel lines to the rail.
1. Line feeding fuel to the rail (top hole) from the pump
2. Return line (bottom hole) which fed from the fuel pressure regulator attached to the rail in front.
Advantage 27 is offline
Old 08-21-2009 | 12:32 PM
Yeah i def have a cool fuel system thats integrated with the fuel pump.. so does that bottom hole on the fuel rail stay open? or does something like a plate block it off?
Greek81 is offline
Old 08-21-2009 | 12:40 PM
Looks like it stays open. See links
Fuel Rail
Fuel Cooler
Old 08-21-2009 | 12:46 PM
Yeah def looks that way.. kinda intresting.. Thanks alot man for all the info, appreciate it greatly
Greek81 is offline
