Dart heads ??? >
Dart heads ???
Dart heads ???
Old 08-31-2009 | 07:37 AM
I thought you can not use the dart heads on a gen 6 block?
baja27 is offline
Old 08-31-2009 | 10:28 AM
yes you can. You need to run the correct head gasket
mrhorsepower1 is offline
Old 08-31-2009 | 12:37 PM
KAAMA's Avatar
Can the Kieth Eickert 2-piece valve cover be used on new the Dart 18* OVAL port CNC'd head without any mods or problems???
Also, I would think the EXHAUST PORT of the new Dart OVAL port CNC'd 18* head is pretty good the way it comes from the factory for a marine blower application---right???...does anyone know if more port work to the exhaust port would be bennificial??? Thanx, Mark
KAAMA is offline
Old 09-12-2009 | 05:19 PM
Originally Posted by mrhorsepower1
Those were the days !
they sure where.
what kind of lift where you running to make those numbers?
wanab is offline
