Blower Engines and plugs >
Old 09-16-2009 | 10:24 AM
Strip Poker 388's Avatar
Rob
Originally Posted by RMPRam
The motors made 1100hp on 92 octane fuel and use the Holley 4150 series 1000+ cfm carbs. If I intend on running it hard, I mix in some 100 LL aviation gas. 7.5 compression ratio and a really mild street roller, solid lifter cam. They have been very dependable.
nice set up on pump gas
Strip Poker 388 is offline
Old 09-16-2009 | 10:31 AM
Rob
Talking
The NGK are supose to be some high tech high heat tingston alloy hand built,they all can melt,I have Been lucky never hurt one of my blower motors,the drag cars on NOS makes paper weights when something goes wrong,ck out the exhaust valve Yea it layed down
Attached Thumbnails Blower Engines and plugs-pistons-spark-plugs-011.jpg   Blower Engines and plugs-pistons-spark-plugs-014.jpg
Old 09-16-2009 | 01:38 PM
Coolerman's Avatar
PF Marine
I use an NGK #R6061-9 plug in my PSI blower motors. It is a plug that PSI recommended for blower applications. Check them out.
Same ones we use, except heat range 10.
Coolerman is offline
Old 09-16-2009 | 04:25 PM
blue thunder's Avatar
What do you have going in to the bosses on the eickert headers RMPRam? Or maybe that is just the pic? Yes, nice setup!
blue thunder is offline
Old 09-16-2009 | 05:04 PM
RMPRam's Avatar
The -12 an line is an overboard dump. There is a -8 an line that dumps overboard, behind that one, and a -8 line from the top of the header that connects to the tailpipe.
RMPRam is offline
Old 09-16-2009 | 06:11 PM
So the tails are completely dry, cool. That sum*****h must crackle!
Old 09-16-2009 | 06:18 PM
RMPRam's Avatar
No, the tailpipes are waterjacketed. The innercooler has 2 outlets and each outlet feeds a tailpipe and one of the 3 upper header dumps goes to the tailpipe on that side.
Sorry for getting off track.
RMPRam is offline
