Builder for a new set of spare engines >
Old 10-11-2009 | 11:03 AM
  #31
CcanDo's Avatar
Are carillo rods with pin oiler tubes and best bolts the way to go ? A set is just under $500/rod.
CcanDo is offline
Old 10-11-2009 | 02:52 PM
  #32
AIR TIME's Avatar
Thumbs up
Dean Gellner engineering 216 398 8500 he has built engines for race teams that race in opa, has been in power boat, outerlimits. has a lot of talent. he is in ohio if that helps. I use him AND I AM IN MASS. ART
AIR TIME is offline
Old 10-11-2009 | 03:59 PM
  #33
We have been using the Oliver rods since 2001-02. The last two sets had 2.10 journals, pin oilers and SPS rod bolts....never any issues. SPS is a good/best (?) bolt, but it is pricey partially because it is because it is exclusively marketed thru Carillo...who is also proud of this bolt. If Oliver wants SPS rod bolts, they buy them from Carillo. In talking to SPS a few years ago, they have elected to not make rods bolts for any other customers. During my research, we found that SPS is a division within a multi-national US company and that its primary market is certified aircraft bolts.
Cat, this is a good project for you. Does anybody know if the Carillo rod is actually any better than any of the other top brands? Do the top teams in NASCAR Cup know what rod is best? They are likely the only ones with the budget to do much testing. I do know that many of the teams are down to the 1.88 or 2.00 journal. How long do they last? I'm sure they change them frequently.
We ended up deciding it was marketing BS, with numerous good products available...like custom pistons.
BenPerfected is offline
Old 10-12-2009 | 12:15 AM
  #34
Strip Poker 388's Avatar
Rob
I think that would be a import price,the real Carillos are 1100-1200 engine builder price,
Weve bought a lot of Crower rods,4340 is around 1000.I beleave they got into the import rob for price, then have the high end usa
Strip Poker 388 is offline
Old 10-12-2009 | 08:07 AM
  #35
CcanDo's Avatar
Strip, That's what I thought, Carillo, C- 42 > H - 76635 S -00, $405.25 Ea., Builder Price. -- 6 Wks. lead time , over $500 Reatail.....Check it out.
CcanDo is offline
Old 10-12-2009 | 12:22 PM
  #36
E-
I've been using Oliver's billet rod with the SPS bolts and have never had any issues.
Dueclaws is offline
Old 10-12-2009 | 05:05 PM
  #37
CcanDo's Avatar
Ben, Due, do you use one or two pin oiler holes in the Olivers ?
CcanDo is offline
Old 10-12-2009 | 08:44 PM
  #38
Mike knows....
Old 10-12-2009 | 08:45 PM
  #39
bob
Charter Member #40
I believe if you don't overtorque the SPS they last a long time and you need to look at stretch to determine when the time has come to replace?
bob is offline
Old 10-13-2009 | 01:43 PM
  #40
I have used Olivers for as long as I can remember. In the bigger hp engines, I use the CARR bolts. The only failure I have ever had was a long time ago in a race boat with a blown alcohol engine making 2000+ hp and turning over 8000 rpm.
Eddie
Young Performance is offline
