Difference between Gen V and gen VI 502 >
Old 10-03-2009 | 06:15 PM
Default Difference between Gen V and gen VI 502
Could some one tell me the difference between gen V and Geen VI 502 engines
I have a 502 Gen V EFI that need a complete rebuild
(block, crank, rods and pistons) are not good.
I came across a Gen VI block and a crank,(all i need is pistons and rods). Will the rest of the components (heads, oil pan, and EFI system) work with the Gen VI block.
thank you
Matys is offline
Old 10-03-2009 | 06:23 PM
Everything will work fine. you will need a different timing cover and chain. oil pan , heads, and intake will work fine. I have a set of 4.53 forged srp flat tops that have less then 10hours with totals seal rings if you are interested. I also have a aluminum polished timing cover if you need it.
The gen 6 is a better block, most of the difference is internal with the oil system.
tx911 is offline
