Difference between a JE and SRP Pistons >
Old 10-20-2009 | 07:14 AM
Default Difference between a JE and SRP Pistons
I know JE and SRP pistons are both made by the same company. What is really the difference between the two? Why do they have two separate lines of pistons?
Here is what the website says: Both JE and SRP are high quality forged pistons. JE Pistons are designed primarily for racing engines and are available for many "race specific" applications. In addition, JE Pistons can be custom made to your specification in as little as 5 days. SRP Pistons are manufactured as a "catalog only" piston and are not available in custom configurations. In addition, all SRP forgings utilize dedicated forgings that reduce the amount of machining required to complete the piston. Since time is money, SRP Pistons are more affordable.
But, is there a material/strength difference?
IHTFP is offline
Old 10-20-2009 | 08:56 AM
hoozeyurdaddy's Avatar
the JE are a professional grade piston that you can have made to your exact spec's if needed, the srp's are a good piston, but not built to the same spec's as the JE's, and have limited sizes. thats what I've been told, not sure how accurate that is.
hoozeyurdaddy is offline
Old 10-20-2009 | 10:34 AM
SRP is more of an off the shelf piston
if you need any custom specs it will be a JE piston
JE is made of better quality materials etc.
how much power are you looking to make with it
Ive made over 800 hp with a regular SRP piston in a turbocharged sbf motor
so the SRP stuff is not junk
cbellamore is offline
Old 10-20-2009 | 11:08 AM
Just looking to make 550 HP or so with a BBC. The reason I am curious is that I believe Mercruiser uses JE pistons in some of their engines and was wondering why they used JE instead of SRP. I already have a set of SRP for my build, just want to make sure they are appropriate for a marine engine before I go any farther.
IHTFP is offline
Old 10-20-2009 | 03:32 PM
Yeah for a 550hp put them in there and dont worry about them at all
they will work great with no issues with that power level
like I said Ive used them on over 800hp turbocharged small block motors without any issues what so ever
Im using a set in my brothers 306 ford motor and we hit it with a 225 hp shot of nitrous on a regular basis its been together for about 4-5 years now without any issues
probably makes about 700hp with the nitrous
Im doing a 550hp 454 motor right now with the stock GM forged pistons that have the small dome on them
so those SRP's will be fine to use
