small blower ? >
small blower ?
small blower ?
Old 10-30-2009 | 02:59 PM
Default small blower ?
What is the height of a small blower single carb like the old 525sc motors had, compared to stock 500 hp intake & carb with 1" spacer under carb. Is it a 177 blower i only want to make 3 lbs boost max what would you recomend. want it to be turn key still but pick up 75 to 100 hp.
rssteiny is offline
Old 10-30-2009 | 03:18 PM
I just measured 21" from the top of the block (lifter valley) to the top of the flame arrestor -- this is with a 4" chiller under the blower.
I have 2 complete setups if you are looking, just pulled them off my 525 Hawks, they are in great shape.
Dave
delsol is offline
Old 10-30-2009 | 04:01 PM
737jetmech's Avatar
Dave
PM sent.
737jetmech is offline
Old 10-31-2009 | 01:06 AM
The blower is about 6" tall and the intake is about 2" lower than the stock 500hp dart intake. You would need about 4" inches more of hatch clearance, maybe a little more, which I don't think you have without adding scoops.
That being said, I would not go with 177's on your 500's. They are too small and are pretty maxed out on a 454. I also don't think you'd gain 100hp with 3# of boost.
Longevity and reliability is not really an issue. I had almost 500hrs on my 525SC with a top end refresh at 350hrs and I was pushing almost 8# of boost. It was turn key and idled like efi when it was warmed up.
Best bet is go with a TBS low profile 250 blower if you want to SC your 500's. They are not any taller than a 177 and maybe even lower. They also don't make as much heat. I still don't think you have the hatch clearance. Probably the only thing that will fit under the hatch is if you go to an EFI Whipple system.
Griff is offline
Old 10-31-2009 | 08:18 AM
thanks griff good info
rssteiny is offline
Old 11-03-2009 | 06:31 PM
What was used on the 575 motors.
rssteiny is offline
Old 11-03-2009 | 10:51 PM
Wieand 256 blowers with dual Throttle Body Injection.
Griff is offline
Old 11-12-2009 | 06:09 PM
I have a blower shop low profile 250 on my hp 500 with a demon carb at 4psi and it runs like a EFI just turned 400 hrs with no problems...
ryanmcclaran is offline
Old 11-12-2009 | 06:12 PM
What kind of hp are you making, is it stock 500hp with the blower or work done other than just the blower.
rssteiny is offline
Old 11-17-2009 | 04:48 PM
Dave
Hey I am looking to buy 2 inercoolers for a weiand 177 if you have a set. call ryan 856-404-2985
ryanmcd53 is offline
