575sci won't start >
575sci won't start
575sci won't start
Old 11-09-2009 | 12:22 PM
Default 575sci won't start
I'm in the Northeast and I need to winterize my boat. I have a 575sci with 250hrs, it's very well maintained. It has spark and fuel. It seems that it turns and will run 4 to 10 turns and sounds like it wants to but won't run. Is there a moudule or an electronic component that controls fuel flow after startup?
scotty575sci is offline
Old 11-10-2009 | 06:30 AM
Things I have experienced:
1. I don't think this is your problem, but I've had them flood. If they do you crank at 3/4 throttle and pull back as soon as it fires.
2. This is the closest I've had to your problem: starts, but won't keep running. Had one injector not firing, if you can believe that. Easy to spot if you remove the flame arrestor and just visual the injectors. Best to pull
said injector off and take it to an injector shop. Actually all of them if one is doing that.
Other than that I have no idea.
Pesky Varmint
Pesky Varmint is offline
Old 11-10-2009 | 11:27 AM
Thanks for responding. There's full flow through the fuel system until the ignition key is released, then it it stops.
Old 11-10-2009 | 05:48 PM
Try the wot thing first,sounds flooded.. if that don't do it then check power at the coil or coils..if theirs power at the coil while cranking its because theirs power coming from the I on the starter solenoid so check it with the key on..if theirs no power check the fuse lead for the pcm,should be on the motor somewhere..
FIXX is offline
Old 11-10-2009 | 07:57 PM
MER Performance's Avatar
When you release the key switch to run is there still power to the gauges? If not key switch is bad, I have seen this before. I can't remember, but is there an oil pressure safety swich for the fuel pump. I'll have to look tomorrow.
MER Performance is offline
Old 11-10-2009 | 08:28 PM
you say "it turns and runs 4 to 10 turns and sound like it wants to run but it doesn't"???? does it start and stall? or is it misfiring on cranking?
tcuda499 is offline
Old 11-10-2009 | 08:57 PM
EWPE's Avatar
I had same problem ,it was a bad kill switch.
EWPE is offline
Old 11-12-2009 | 06:12 AM
Sorry I can't really help..... seems like a few good suggestions from the above. Please keep us informed on the fix...... incase any of us run in to the same problem......... Good Luck....!!
Here's Johnny is offline
Old 11-16-2009 | 08:50 AM
Great feedback guys. I'll be looking at today. The cutoff switch was bad, but it didn't change things.
