454, upgrades? >
454, upgrades?
454, upgrades?
Old 11-12-2009 | 07:35 PM
SOX's Avatar
SOX
Semper Fi
Thanks Dave, This is in a 253 Checkmate at Tomes. I ran the engine #'s today and merc. told me It is a '96 454 350 hp. (I guess that it at the prop.) I verified it has the forged aluminum pistons and forged steel crank. and the rectangular ports. From what I have been told 525hp is doable on this platform. That would put this boat in the mid 70's which is good enough for me.
SOX is offline
Old 11-13-2009 | 05:17 PM
If it is indeed a Mag engine then you could get buy with just freshening up the bottom end. You will have to go roller to get the performance. Call RMbuilder for your cam, lifters and springs. Freshen up your heads while you have them out. Get a good set of aftermarket exhaust with long risers. Allow some money to upgrade the oiling system, with better flowing fittings and hoses. Make sure the oil cooler is large enough for the added power. You will probably need a bigger carb also. Be prepaired to spend a bunch of money to do it correctly. Good luck with your project!!
jeffswav is offline
Old 11-14-2009 | 03:15 PM
SOX's Avatar
SOX
Semper Fi
right on thanks. I would plan on having a proffesional do any motor mods. As I don't see the value in doing the work wrong the first time. All it will take is one rookie mistake and I am floating down the bay getting towed in by some jetski...
SOX is offline
Old 11-15-2009 | 08:45 PM
I do all my own wrench work. Like assembly, pulling the engine ect... I have a local machine shop do the technical stuff.
jeffswav is offline
Old 11-17-2009 | 07:06 PM
blue thunder's Avatar
If its a mag I would put a blower on and run the stock cam. Then you can get by with that exhaust and just a carb change. That would be wisest if the engine is in good condition.
If you want a second opinion or anything say the word. I am off next week and available. I love boat shopping
PS, I just always wanted to use that smiley, nothing intended there. Now where did I leave those doritos......
blue thunder is offline
Old 12-12-2009 | 08:30 AM
SOX's Avatar
SOX
Semper Fi
I am not huge blower fan but it does seem like the easiest way to gain hp.
SOX is offline
Old 12-12-2009 | 09:18 AM
fireboatpilot's Avatar
RIPSTA Racing Team
If you just want to swap it out, I have 2 engines for sale. Matched set of 468's. 580hp on carb. Long blocks for sale with 14qt oil pans and I have intake I'll toss in. All your accessories will bolt on. Forged lower ends, eagle rods, Merlin heads, roller valve train. One is ready to go $5K. The second is apart needs assembly. It spun 2 rod bearings, lack of oil. Block is checked, align bored, honed, crand is checked, cut .010 on rods, new set of rods, bearings, gaskets, rings, 8.5 pistons. $3K. I'm right up in Philly. Pm me if interested after you get estimates on having an engine built. I also have a set of B&M 250 blowers that will go on these engines and make around 700hp. I will seperate them. Bill
fireboatpilot is offline
Old 12-13-2009 | 04:12 PM
SOX's Avatar
SOX
Semper Fi
Thanks Bill, I bought the boat and will run it next year as is. I am going to take my time and possibly next winter add some hp but first I want to run it for a season to make sure there arer not any issues I "need" to take care of first before I do the option al upgrades.
SOX is offline
