? on pulling the motor >
Old 11-22-2009 | 02:58 PM
Default ? on pulling the motor
Im ready to pull my 500hps out for repower, question is what is best way to pull the motor from the bell. pull bell bolts out of block or pull the 2 boig bolts going down through bell and pull bell with motor.
rssteiny is offline
Old 11-22-2009 | 03:03 PM
GPM
I always remove the bell with the motor, it's hard to get to the bolts in the splash sheild, and the sheild is in front of the flywheel.
GPM is offline
Old 11-22-2009 | 05:29 PM
Absolutely pull the bellhousing with the engine. Just pull the 2 rear motor mount bolts.
Eddie
Young Performance is offline
Old 11-22-2009 | 05:35 PM
Default Fixx
Remove the drives first tho!!!!!
FIXX is offline
Old 11-22-2009 | 06:30 PM
Yea done that
rssteiny is offline
Old 11-22-2009 | 06:39 PM
pull the 2 rear mount bolts and hoist her on out ,way easier to pull the bellhousing out of the boat.good luck
DrydenPERF is offline
Old 11-23-2009 | 03:43 PM
blue thunder's Avatar
I'm curious, where are you located in PA?
blue thunder is offline
Old 11-23-2009 | 03:49 PM
Williamsport Home of (little league world series)
you
rssteiny is offline
Old 11-23-2009 | 04:11 PM
Lebanon PA. The wife is from Williamsport. We will be doing thanksgiving in Muncy Thursday. Are you near there?
Old 11-23-2009 | 04:16 PM
Panther's Avatar
Frank's Marine Service
You don't have to if you have the forward clearance but you probably should, especially if it's your first time!
Panther is offline
