finish on Mercury labbed props? >
Old 04-11-2002 | 09:39 AM
Cattitude's Avatar
Default finish on Mercury labbed props?
I'm looking at a 30p bravo to buy, claimed to be labbed by merc.
I was under the impression that merc always put a satin finish on their props when they labbed them? I know my 28 has that finish. This prop is definately labbed but is shiny (stock finish).
I prefer to stick with Merc's work when buying a second hand prop. Can anyone verify?
Thanks,
Ken
Cattitude is offline
Old 04-11-2002 | 01:33 PM
HavasuCat
I have owned six Mercury labbed props and all had satin finishes.
Old 04-11-2002 | 03:46 PM
djm's Avatar
djm
There is the duratec finish that comes on Mercury's Quicksilver Mirage line of props. It's shiny and supposedly keeps corrosion down.
djm is offline
Old 04-11-2002 | 06:10 PM
Mbam's Avatar
Offshoreonly Advertiser
The labbed props from Merc have a satin finish. DJM, the Duratec is on the stock out of the box props.
Mbam is offline
Old 04-11-2002 | 07:39 PM
Goody76
If it was labbed it should have a sheet and if it was done by merc Denis Cavanaugh's name should be on the paper. As far as the finish when I get mine back from merc I can use it as a mirror!
Old 04-12-2002 | 01:13 PM
JAX25OUTLAW
Thumbs up
my labbed prop is not the super shinny kind but I have seen both types come back. Feel the front edge of the blades if it feels like it will cut you and absolutely puree a manatee then it is labbed. You can also call merc, they keep the blueprint for every prop they lab so they can fix it when we ding them up. Just give them the serial number and they can tell you if it was done there or not.
Old 04-13-2002 | 11:21 PM
Blackhawkdn
If the prop was bought as a lab from mercury and was not a rework the number part number is stamped with an L. If its a rework no L will appear but in either case the leading edge will be razor sharp
26sonic
Prop Talk
10
04-05-2011 10:03 AM
Donzi26ZX
Prop Talk
2
07-16-2005 09:32 AM
formula271
6
08-28-2002 11:42 AM
formula271
08-19-2002 10:43 PM
formula271
2
08-04-2002 11:44 PM
